This message indicates that an attempt to find the specified MLAG port in the given VLAN has failed.
Check the configuration and ensure that MLAG port is part of the specified vlan. Also make sure that the IPMC configuration on MLAG peer switches is consistent. On dual-MSM systems try failing over to the backup MSM. Stackables or single MSM systems may require a reboot to correct the problem. If the issue persists, please escalate to engineering.
Error
Unable to find MLAG port for VLAN %vlan%, port %mslot%:%mport%
| Name | Type |
| vlan | String |
| mslot | uInt16 |
| mport | uInt16 |
